Motorola H730.
Turn your BCM2074A2 off and then open flip on H730 and connect to it or repair if the light turns steady blue.
what do you mean repair if light turns steady blue
Jackie- What you're seeing is probably the Bluetooth MAC address of the bluetooth headset. This is the unique identifier of the device which typically is hidden after your phone reads the common name (Model) of your device. By re-pair, I mean that you delete the connection or history on your phone of your H730 and then put your headset back into pairing mode by swinging out the boom and waiting for the steady light and then you start the phone to search for the headset. This may resolve it. Mark Motorola Support
I tried doing this but there is not light on the device... Neither am i able to pick up or disconnect a call from the Bluetooth. It doesn't automatically pair either...
Nothing works. I can't contact Motorola as it seems there is no longer any support for this bluetooth. Of course; it worked great and doesn't stick in your ear but lays against it so it's comfortable to wear for hours, inside or outside regardless of the weather.
The few that are out there are ridiculously expensive.
