GPS Logo
A
Anonymous Posted on Jul 19, 2014
Carnt seem to get maps i download to work on my tom tom
I down load maps & speed camara on to a sd card but now my tomtom not working .so i borrow same divces but carnt get it to work.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on May 17, 2007
SOURCE: Tomtom One
If you have the programs downloaded from tomtom home then you need to copy them to the sd card that you purchased. In the home program you can choose to install the programs and map to the sd card. It takes a bit of a search to get the tomtom home program understood. The credit card with the codes is an authorization code for the program.
kral_baho
  • Posted on Dec 02, 2008
SOURCE: TomTom One map download process
baho
soras46
  • 47 Answers
  • Posted on Mar 01, 2009
SOURCE: Tomtom one cant unlock maps
well,then there is only one way, that definetly works, ttsystem patcher, if tomtom company doesn;t want to help, we can do it our self ;)
there are lots of warez about ir ;) in www.twingine.com ;)
Anonymous
  • Posted on Mar 06, 2009
SOURCE: tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Anonymous
  • 515 Answers
  • Posted on Apr 13, 2009
SOURCE: Downloading Free Maps for TomTom GO 720
No maps found issue:
http://www.tomtom.com/support/index.php?Language=1&query=no+maps+found&FID=9838
Update download for tom tom xxl 540s is too big for unit, lost all maps
Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
Hope this information came in handy.
My new tom tom go 300 gps has nosd card with maps
If you don't have maps, you can't navigate.
So: Get an SD card. Download the maps.
Question for you: How did you wind up with a navigator with no card and no maps? You might consider taking it back to the place you bought it and exchange it for one with the minimum necessary to make it work.
Tomtom not reacting
If you deleted your card your program is more than likely lost along with all of your maps. However never fear. If you had an account with tomtom you should be able to download a file from them that can update your sd card, But be aware they will probally charge you. Make sure to tell them that you were downloading one of THEIR updates.
Aug 22, 2009 • GPS
1helpful
3answers
Iv got an backup issue with my tomtom one.after backup with microsoft windows xp backup and restor software,i wrongfully formated my tom tom one,now when i restor my backup with windows xp...
I do some work with TomTom - it's possible that if something interrupted or went wrong during the install, the map could have been deleted. TomTom is aware of the problem and is working to fix it - if you are map-less, call support (866 486 6866) and we can work on getting you a new map.
1helpful
After updatetd from tom tom home does not work anymore
you are using the tomtom update application on PC?
your download is complete? New charts and firmware?
Make sure you download right firmware.
If not download right one.
Besure map download wasnot broken off because of time-out.
Format after backup your SD card. Start reinstalling firmware and then maps. Be sure not too have too small memory size SD card.
I have been in this mess. TY TomTom for your bad service
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
1helpful
Tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
36helpful
4answers
Tom tom one xl wont accept SD card with map on
Hope this helpful
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
