SOURCE: Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
SOURCE: Samsung HLN617W DLP 61" TV only show green color
Check your color wheel.(These shatter) Can purchase these at Electrified Discounters
SOURCE: Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
SOURCE: I hardly watch my Samsung HLS508SW picutre has an
it is very hard , call samsung back this dlp chip problem is under recall because of this issue
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
