The screen turns on but when I hit start the belt does not start proform 397
Verify the safety key is present and functioning. Most machines use a magnet and any strong magnet will be enough to close the circuit.
Most treadmills meet there demise from a faulty lower control board under the hood. It can light and be mostly functional, but still have issues. Boards are not very cheap but are very easy to install.
Search for options on fitnessrepairparts.com.
Make sure to take an image of the original board to copy the wire location/connections.
Boards often go bad from an array of issues, but verify the condition of the underside of the walking belt is not black and the deck is not worn. Lack of lubricant and too much friction on the belt system usually overloads the board with heat and damages the board.
