Somhow my camera settings has been changed and now I can only record black &white videos, I would like to change the settings and can record color videos again .thx
SOURCE: cannot get back to Automatic mode on video
With camera dial on video, rotate the scroll wheel located around the direction button until Standard is selected. DO NOT push function set first like the manual says.
SOURCE: White balance settings and color temperature
Canon has a chart of the approximate settings they use in their manual. it states.. daylight - 5200 shade - 7000 cloudy/twilight/sunset - 6000 tungsten - 3200 white flourescent - 4000 flash - 6000
SOURCE: video shooting went from color to b/white - how do I get it back?
Press the Function button and scroll down to middle (fourth) icon on the left side of the LCD, the My Color mode. Is it set for BW or C? Use the left/right arrow key to select OFF. Press Function again.
SOURCE: When I try to record video It is in black and white
on movie mode, use the control dial to change the remocrd mode to Standard, also set My Color to Off.
SOURCE: Sound gone from camera video recording
Reset the camera to factory settings.
If still you are experiencing the same problem, then you will need to have your camera reviewed by a qualified technician to have it repaired, since it requires to open the camera and evaluate the main board and microphone circuitry..
Best regards,
