Light on my ceiling fan will not turn on with the remote. It's a Canarm model BCF-00I9X2
I assume this used to work and fan control by remote is still working<?>. If neither fan nor light work, replace remote batteries and check remote code switch. Else;
If fan has pull chain for light, make sure it has not been turned off. The remote lamp button is toggle ON/OFF so you will need to press lamp ON/OFF more than once every time you pull the light pull chain. Still fails, test light bulb. If known good bulb, the receiver in fan will need removed and tested.
