With basic "lesser brand" Android tablets such as the Zeepad starting from about USD40 from the bigger online retailers, it is unlikely to be worth reparing the cracked screen. BTW, a repalacement screen by itself CAN be bought for about USD25, from which you will probably also conclude that a repair is uneconomical.
With basic "lesser brand" Android tablets such as the Zeepad starting from about USD40 from the bigger online retailers, it is unlikely to be worth reparing the cracked screen. BTW, a replaacement screen CAN be bought for about USD25, from which you will probably also conclude that a repair of the screen of the device is quite uneconomical.
On your home screen tap the the app button,then tap the screen saver app. Tap Enable Screensaver to turn the screensaver mode on or off. Then remove the check to "service enable" check box.
1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
It is different depending on which zeepad you have. From powered off, which yours sounds like it is:
1. Hold down both volumes and power at the same time. You should get an android on its back opened up.
2. Press both volumes at same time to open up a small blue text menu.
3. Then use Vol - and Vol + to navigate the Recovery mode.
4. Select "Factory Data Reset"
5. press power
6. choose "yes" from the menu
7. then press power again.
If this does not work try holding down the volume and power at the same time.
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
I ordered a Zeepad 7DRK from Nomorerack.com it did the same thing. I emailed [email protected] and was sent back a response that basically gave me instructions to return my Zeepad 7DRK.
