LG KG800 Cellular Phone Logo
A
Anonymous Posted on Jul 17, 2014
How to replace battery
Existing battery charge does not last long
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
2answers
Philips DCP855/37 Portable DVD Player...when I try to charge up the lithium battery it does not charge. The directions say to turn off the power and the green charge light will turn on. When I plug it in...
Batteries in these things don't last very much; it is most likely a bad battery. Replace the battery with a new one and your problem should be solved.
2008 Yamaha TTR230 Draining Battery
Replace your battery with new one because your existing one most likely became faulty with age.Even if you charge it it wont last. It is time for new one.
Touchscreen and charge
As far as the battery not holding a charge goes, some batteries have a memory, so the amount of current you recharge becomes the total charge available. Some other batteries just don't recharge nearly enough times to be worth it.
1helpful
2answers
My Insignia HD DV HDMI will not charge!!!
Occasionally the batteries in the camera die- so no amount of charging will fix that, but does the camera work when you have it plugged in to charge? Most cameras will run from the  charger , even if the battery is dead. If it runs from AC (wall plug), but not battery, it probably the battery, but occasionally it is the circuit in the camera that charges the battery. The last resort is an external battery charger (not all cameras have them), but if you can charge the battery elsewhere, then it is the circuit in the camera- you'll have to buy an external charger if one exists
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
My battery lasts for about a dozen snaps only
what battery type and size/capacity are you using?
All idiot lights came on. Won't hold a charge for long.
chk charging noltage at battery posts. should be in 13.6 to14.2.. Is charging good at 13.8. If thar's good, your battery is not.. Your alternator won't last too long with a bad battery. good luck
2answers
Nokia mobail n81 charging not ful miy problem pleeis miy halp
Use your phone and completely discharge the battery.Then charge the battery.If again the problem exists then either it is your phone's software problem or it is time to replace your battery.Update your phone's software using nokia software updater and if the problem again exist replace your battery..
Have a motorola v3X Suddenly not charging
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Jan 14, 2009 • Nokia 3650
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
