This is not a 5330 question but a system question. This phones will work on more than 1 system. On a Mitel 5000 or Inter-tel 5000 system the feature code is press the digit 4 then dial the extension number. Hope this helps.
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call,
but you want to pick up your last line (in this case we will say we have
6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press
** (star, star) and press line 6, line 5, line 4, line 3, line 2, and
line 1. Then I press ** (start, star) to signify that I am done
programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
From ext 10 or 11: press feature 00 press left intercom twice press right intercom once enter extension number press ** then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom ) press** press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
Two of the above codes work for me, so let's figure out what you're doing. First of all, did you convert the intercom calls to ringing on all calls? If I have auto answer turned on, I can't pick up anything.
If the phone is ringing, I can use 40 and 41xx to pick it up. I can retrieve a call from hold by dialing 53x where x is the line number on hold (just in case you're trying this with a cordless or single line set).
By default, all extensions are in pickup group 1, but 41xx directed call pickup will always work if the Call pickup deny is properly set as you indicated
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
