Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
A
Anonymous Posted on Jul 17, 2014
What is wrong with my wave runner
A light blue smoke continues to flow out of the jets when i start and run the wave runner
txslim55
Level 3:
  • Yamaha Master 1,104 Answers
  • Posted on Jul 07, 2015
txslim55
Yamaha Master
Level 3:
Answers
1104
Questions
Helped
409708
Points
5454
There are several suppliers of smokeless 2-stroke oil
Mel Hansen
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2014
Mel Hansen
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
899
Points
Make sure you are using Yamaha oil not an off brand. It does make a difference.
How do you winterize a 1993 Yamaha wave runner 2 stroke, everything we have seen says to just fog the plugs no anti freeze? is this right and if not where do you put the anti freeze in at?
NO ANTIFREEZE!!! simply hook up to the flush fitting and while running start spraying fogging oil thru intake . you want to "load" it up with that stuff and don't rev high for about 3 or 4 min the just disconnect battery and spray motor and pump down with WD-40
Jet ski wont start
does it have spark at plugs ? carb clean and fuel new ?
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Yamaha wave runner dies at high rpms.
An engine that dies under load but starts ok and idles ok has a fuel blockage in the main jet . Possible from water in the fuel in the carby. Water will not pass through the jet and blocks up the hole A trick that is used is to place a pint of metholated spirits in with the fuel. It breaks down the surface tension of the water and allows it to pass through the jet.
Jul 28, 2013 • Motorcycles
1999 Yamaha wave runner 1200 XL won't start
Check to see if you get power to the starter when you try and start it. If you do, they you may have a bad starter. If not then you may have a bad switch or even blown fuse.
Jun 11, 2013 • Motorcycles
I was riding the daytonia 770 jet ski and the fuel gauge quit working and could not get speed up over 30 miles an hour. do you have any suggestions what it could be?
Hi, I was raised on a marina and road more wave runners and jet skis than the average bear. One of my wave runners started having a problems like yours sounds to be and I look it in and let them run test on it. Mine had an electrical problem causing it to think it had problems that it really didn't have. They just reset some of the settings and it was fine after that.
One more thing...ha you checked it's impeller? Dings on that w/hinder your speed.
Best of luck to you....and by the way, the cost was minimal.
Happy Jetskiing!
Apr 11, 2011 • Boating
03 yahama fx 140 waverunner smoke coming out of water pilots and will only go about 25 to 30 mhp normal is about 60
I was raised on a marina and worked at the waterfront for quite a while. I had wave runners, jet skis, boats, you name it.
Whew, that sounds serious. You probably need to take it to the shop and let them run some test on it. Your problem is bigger than myself.
2helpful
2answers
Excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
