Coil caught on fire and broke in half
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: Need manual
Thanks to an earlier solution by huuum, here's a link to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
SOURCE: Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
SOURCE: I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
