Live view don't work. Will take picture but cannot display image. images cannot be opened on PC. Sound only works on video clips
If live view does not work is not to dramatic, but when you can't open pictures you took it becomes scary. With not to be able to open your pictures, does that mean the .jpg gives an error, or does the screen stay boac?
If so, I think we have to fear the image sensor or the connection to the image sensor is defect.. I don't think it will be worth trying to repair a 10 year old camera, but if there was never any leaking of batteries in the camera, that could have oxidised or even eaten contacts or cables, perhaps you once could open the camera, before trowing it in the bin.
Check if any flat cable came lose of something else gets you attention.
I would start saving for a new camera. (I'm saving to for a new camera, but for a different one)
SOURCE: HP Photosmart M425v Wont ransfer videos
try using a differint progam to uplode your videos & pix or check your conection there mite be something wrong with your usb cable.
SOURCE: HP Photosmart M407 Digicam
The issue is probably the button board on the camera. To open the camera, remove the six screws and pry open the camera from the bottom of the camera to remove the outer casing. Turn the camera so that the LCD is facing. Remove the aluminum frame around the LCD that holds the button board in place. Check the button board for mis-aligned or damaged discs (ie playback or view buttons) The discs are taped and may creep out of position. If they are out of position, push them back with the blunt edge of a screw-driver. If it looks fine, reassemble the camera.
SOURCE: transfering the images
be sure about the source selected in the software, or try the old way and use your cam as a mass storage, it will be like any flash memory, go to My Computer and open the new drive !! and enjoy
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, service may be required.
Thanks for contacting FixYa.
