Email address [email protected]
SOURCE: Brother HL-2040 printer
if someone directed you to take the printer apart, there's probably a panel or door that isn't closed or in place all the way. Take it all apart again and start over.
SOURCE: No IP address on Brother Printer
I am assuming that it works whn it is connected directly to your system, as you told that you got your printer replaced. And as you may know that connecting through CAT5 cable is the RECOMEND way..but thats what every1 else tell.
So now, the 1st doubt that comes in my mind is about the OS you are using. The model you are using is compatible with Windows, Mac & Linux.
The 2nd possibility rises have you installed the appropriate driver for the printer you are willing to use and check your wireless settings too.
Now the 3rd possibility is that maybe there is something wrong with your router. Maybe you should make sure that the router is working properly.
SOURCE: Brother 2040 yellow toner light on & won't
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
SOURCE: Scanning to email on MFC-9840CDW Laser Printer
This is a little dated, and I hope you have found your solution already, but for everyone else:
Press the # button
Use the directional pad to scroll over to the @ symbol. When It is underlines press OK
To insert a ., press the * symbol, scroll over until . is underlined and do the same as above.
