I was charging the phone, when i went back to it the phone will not turn on ,a green light is on permanatly on the top right hand corner of the front of the phone
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase. #Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
Make sure the battery is charge properly
Turn on SONY XPERIA T LT30p smartphone
Don't forget to backup all important data
Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
Flashtool in the applications from Sony can be download from Sony website.
Flashtool software need to installed in you computer and ready with USB data cable
Make sure SONY XPERIA T LT30p battery is charge properly or full charge
Power off SONY XPERIA T LT30p
Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
Make sure the battery fully charge
Do not forget to backup all important data
Turn off the SONY XPERIA T LT30p
Press and Hold together: Power Button + Volume Up Button for several seconds
Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
there's only two situations here:
1- you messed up the phone battery and cables inside.
2- you need to reflash the original room of the phone.
here's a small guide about reflashing: http://xperiafirmware.com/8-firmware/14-sony-xperia-ion-lt28
hope I helped don't forget to hit thanks!
You need to try the update again and choose the REPAIR option. Unfortunately you will lose your downloaded apps/games and save games. Your pics, vids and music should remain though.
It fall and when i on back the lcd of phone wasn't there.i can see the red light on the top of phone which is the sign that my phone is charging but there's no lcd!
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
