It keeps saying the ringer is off and i cannot get in turned on
SOURCE: how to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
SOURCE: How to turn off telephone ringer on handset for
Just press the down arrow on the center button
SOURCE: Please tell me how to turn the phone ringer back
Pick up the handset.
Use the volume up and down key to pick the ringer volume level.
Your ring will come back
SOURCE: how do you turn ringer on and off on a uniden
hello. To turn the ringer off on that phone you need to get into the menu. The way you get into the menu is press and hold the menu/cid button for 2 seconds. Then press the arrow down button until you highlight the ringer volume. once the ringer volume is highlighted, press the select/channel button. that will rotate you through the 3 available volume levels. High, low and off. as you are pressing the select/channel button the handset sounds a sample of the volume level. when you hear the volume level you want simply press end and that will store your volume to the off position. to turn it back on, just repeat the above steps but select the proper volume level you want and then hit end. I hope this helps.. Don;t forget to rate me. thanks !
SOURCE: I just have a question. We have a Uniden 5.8GHz
My phone is a Uniden TCX905 model.
Ringer Volume
Choose from three ringer volume settings (off,
low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
