Samsung DVD-V1000 DVD-VCR Combo Logo
A
Anonymous Posted on Jul 16, 2014
Why is the VHS eject button stuck on my samsung v1000?
Artie
Level 2:
Champion:
New Friend:
  • Expert 236 Answers
  • Posted on Jul 18, 2014
Artie
Expert
Level 2:
Champion:
New Friend:
Answers
236
Questions
0
Helped
56436
Points
309
Button stuck - not cassette stuck in the player? If there is a cassette stuck, the machine has to be opened to get the tape out.
Why my Panasonic VCR not ejecting?
Motors or drive belts not working.
Google
panasonic model tape not ejecting
https://www.google.com/search?q=%E2%80%8Bpanasonic+model+tape+not+ejecting
Press and hold the [EJECT] button on the unit while plugging in the power cord. You can also try on the remote control to press [Drive Select] to select VHS drive and then press and hold for more then 3 seconds the [STOP] button.
The VHS tape is stuck how to eject the VHS tape.
4answers
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
How do I transfer VHS to DVD
you need a dvd recorder and a vhs player..hook up the vhs player to the dvd reorder...you can buy the leads off Ebay..job done
Eject button stuck
It will be better to but a new one
The vhs switch is stuck and isn,t all the way out.how do i fix it?
Make up a soapy solution with water and dish soap Take a toothpick and dip it in the soapy water and hold it where the button and the faceplate meet. Let some solution run off the tooth pick and start working the button till it frees up.
Can I copy vhs to dvd with my samsung DVD V1000?
only if the dvd is a dvd burner can you copy it to dvd from vhs if it isint go to walmart or best buy and get a dvd burner and hook it to you combe then you can record vhs or dvd to the dvd burner
Well ont eject all the way out
There is a problem with the loading basket, or the VHS tape is stuck inside and the eject mechanism can not cycle the tape out. To check this, open the lid so you can see the tape, if it is wrapped around the head and roller, hit the eject button to see if the tape is being pulled or jammed, cut the tape with scissors to free it up to see if it will pop out. If the tape is okay, it means you have a faulty loading basket.
DVD door won't open
It's likely the drive belt that controls the sledge the disc goes on has perished or fallen off. It should just need replacing.
8helpful
2answers
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
