Ok, I have an 03 E500 everytime I don't drive this car for an extended time, something happens. When I inserted the key, I got this error message "Stop car too low", when I started the car, I noticed the hydrolics in the back rose up. What's going on, anyone know?
Sounds like you may have a leak in the airmatic suspension struts on the rear. These govern the height of the car in different modes. Not an immediate problem unless you are loosing a visible amount of fluid but it will only get worse.
To check if you have airmatic you will have buttons just behind the gear lever which can be used to put the car in to a stiffer, lower mode or to raise it for rough ground
