I was photocopying then an error code E007 appeared on the copier screen
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: my canon copier ir-2022 shows
The firmaware in the machine needs reloaded. You will need a canon service tech to reload system software. This will update the software.
SOURCE: My canon iR 2022 is
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
