How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
In my phone's Blue tooth menu, it shows that the Sound Logic Ear Buds are successfully paired,just when i select device info, it says "not connected" as the status. Every time though, when i try to connect the ear buds again, it says on my phone, failed in connection. What do I do in order to successfully connect my blue tooth Sound Logic ear buds?
My daughter's Samsung U600 connects to her Clarion Alpine CDE 103BT
radio OK, and she can call from the phonebook in the Clarion OK.
However an incoming call shows up on the Clarion but then is
immediately dropped. The chap who fitted the Clarion said it would
answer calls automatically. Even if this wasn't the case and she had to
press a key on the Clarion to pick up the call there wouldn't be enough
time for her to do this.
Is this a Bluetooth connectivity problem or is there some setting that would correct this?
As far as I know, as long as you put the SAME code on PC and phone, it will work. Works with nokia and my vista PC. keep it simple, ie try 0000 (zero, zero,zero zero) on both phone & PC
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
To pair a Samsung Intensity cell phone with a Plantronics Explorer 245 headset, follow the 10 steps below:
1. Turn your cell phone on and your headset off.
2. On the Intensity, press the Menu button (the center round button) and from the main menu, go to Settings & Tools (in the bottom right corner).
3. Select item #3, Bluetooth Menu.
4. Select item #1, Add New Device.
5. If your Bluetooth radio is currently off, you'll be asked if you want to turn it on -- select Yes.
6. Turn on the Explorer headset. After a few seconds you should see either red and blue flashes or just blue flashes. If you see red and blue flashes, go on to step 7. If you see only blue flashes, hold the Call button down (the button on the side of the earpiece) for five or six seconds, until the LEDs begin to flash red and then blue.
7. On your cell phone, click OK on the screen telling you to place your device in discoverable mode.
8. The phone will search for Bluetooth devices in the area, and the Plantronics headset will appear at the top of the screen. It should be labeled "245Plantronics" or something similar. Once you see the headset appear on the screen, press the menu button to stop the search.
9. Press the menu button again to pair the two devices.
10. A message will appear once pairing has been completed, and you will be prompted to connect the phone to the headset. Select Yes.
The connection has now been established between the two devices, and you can use your Explorer 245 as a hands-free headset in conjunction with your cell phone. To see information about the headset (such as what services it offers, what its Bluetooth address is, or how long it has been paired to your phone) scroll down to its name on the phone's Bluetooth Menu and click the right option button to bring up the device's Options screen.
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
