?Read owner's manual
Lexmark Lexmark X8350 Owner Manual
SOURCE: Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
