The ice maker is not working.. When the reset button is pressed it empties ice and refills with water, but doesn't continue making ice.
SOURCE: Samsung Side by Side RS2544SL Freezer will not fill tray with water
Your problem may be in the water supply. Where the water connects to the back of the unit there is an electric valve, not a pump. The electric valve inlet orifice may be restricted, Shut off water supply and clean or replace the electric solenoid valve.
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
SOURCE: Ice maker quit working
go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
