HOW DOES WESLO CADENCE 5.8 SET UP
SOURCE: i have weslo cadence 860 ,the key is not working
Is it the magnetic key or the red one you slide into the slot.
SOURCE: weslo cadence treadmill fuse keeps tripping after
dear sir,
this types of problem occurred due to reason given below:-
1) if your motor belt too jammed. motor need more power to rotate it.
2) motor internal coil insulation problem.
3) semi short circuit in the internal control circuit.
how to check :-
at first look the label on motor try to find out the motor Ampere then measure with a ammeter if it drawing current is high from label mentioned ampere
then motor is faulty.
for check the circuit if u don't have any previous idea plz contact with qualified technical person.
hope that u get the answer.
thanks
