Why cant log into my account to read mail
Why indeed, when there's no notion of why you can't or won't or wouldn't! Is there some off-putting message it offers instead of letting you login, or do you just need to enable a few script hosts (Yahoo.com and about 5 more Yahoo ones) having installed NoScript, to get webmail running? Perhaps the firewall or DNS things at work changed if that's the route you're logging in from. Something changed from having internet access to your browser or your firewall, and perhaps it changed the response you get logging in?
SOURCE: account is no longer active
hi,
My name is hadeel and my email not working any more, I am from united arab emirates, Abu Dhabi
I am failed to open my email through my passward since two days which is [email protected]
will u pls check for me what is going on because i heard there is some huckers doing some problems in UAE which happened to my cusine last week in dubai on the hotmail and the support technical service for the hotmail return it back to him.
so would u please do the same as well...you can contact me on [email protected]
SOURCE: e-a-mail security problem?
I have experienced this same pop-up. I have been a Yahoo mail client for the past 14 years and I can tell you with a certain level of confidence that this is something you don't need to worry a about. It's a conflict between the yahoo mail server and the yahoo messenger server.
anaanymous
SOURCE: problems configuring Yahoo mail for Windows Mail
The most common causes of these error messages are problems with Internet connectivity and account settings configured incorrectly in Outlook or Outlook Express.
Perform the following methods in order. If one method does not resolve the issue, move on to the next one. The methods are as follows:
Method 1: Start Outlook in safe mode
Method 2: Create a new e-mail profile
Method 3: Delete suspicious messages from your mailbox
Method 4: Check your antivirus vendor’s Web site for additional suggestions
Method 5: Remove, and then reinstall Outlook Express
Method 6: Verify that all SMTP e-mail addresses in a distribution list are valid
Method 7: Examine the configuration of your firewall software
If your antivirus solution includes an e-mail scanning feature, you may have to perform additional configuration tasks to use Outlook or Outlook Express with the antivirus e-mail scanning feature.
Antivirus software that is known to have caused this problem includes products by the following vendors:
SOURCE: Yahoo locked my email account.
nothing can be done to this unfortunately due to yahoo security reasons... try using outlook and configure outlook express...hope something can happen... but mainly u have to mail yahoo stating this ..
SOURCE: cant log into yahoo mail
I had the same problem 2 days ago, I tried a lot of things and finally got the the solution.
It was a DNS resolution problem
In my wireless netgear DG 834GT router settings (through IE), at the DNS address I unchecked "get automatic from ISP" then checked to use the primary DNS at 4.2.2.2 and secondary DNS at 4.2.2.3 ( I followed the Router's manual instructions )
Maybe u have to see in your Router manual what address u have to put for primary and secondary DNS?
Good luck, hope this will help
