Google
Sep 10, 2015 - 27 posts - 18 authors
Check your apps from Google Play Store > My Apps or Application Manager list. ...My phone details: Kyocera Hydro Vibe model C6725.
2 hours ago - my Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is ...
Jan 2, 2015 - I rooted my hydro and installed beats audio but now my sound does ... of something like this happening... without a working recovery like CWM.Missing: flickering static
. Download BackupTrans Software's "Android SMS + MMS Transfer" software .It help us extracts SMS and MMS messages from any Android device and stores them on the PC.
2. Connect your Kyocera Hydro to your PC via mini USB cable. "Android SMS + MMS Transfer" will scan your drive and create a list that it can sync to your computer.
3. Click on "Kyocera Hydro" under the list of devices in the left-hand panel of the software.
Select the messages from the list, click "File" -"Print SMS and MMS." Select your printer and then click "Print."
App Option
4. Press the "Home" button on the Kyocera Hydro.Tap the "Google Play" icon to open the application market. Search for "PrinterShare Mobile Print." Tap "Install" to download and install the software.
5. Both the printer and the phone need to be on the same wireless network.Tap the app to searches the network for the printer.
6. Tap "Messages" to open your SMS and MMS messages in PrinterShare. Select the wireless printer.
Manual Method
7. Click on the messages and then tap"Copy message text".
8. Return to your Home screen and then open the email app.Compose a new message to yourself and paste the messages you want to print.Tap"Send".
9. Open the email on any computer connected to a printer and then click "File," and choose "Print".
10. Then you have successfully print your message from Kyocera Hydro.
If you are already on the "frequently called" list, look in the lower right corner. There is a symbol that looks like 3 gray boxes stacked vertically. Press that and a menu will appear. The third item down in that menu is "clear frequents". Press that and you should be good to go.
To get to your "frequently called" list, from your home screen press the green phone symbol on the bottom left. From there, look at the menu at the top (gray phone, gray clock, gray person) and press the gray person symbol. You should now have an aqua heading that says "Frequently Called" and you can follow the instructions above. Best of luck!
From your home screen, press the green phone icon (lower left of your screen). At the calls window, press the icon located center top of your screen (looks like a gray analog clock). This menu is labeled "All Calls" and shows recent calls, with the most recent at the top. Hope that helps!
Even if I had your drawings & specifications...
I would still have to LOOK at your KYOCERA
to determine what/where the damage... then
the remedy might be...
My suggestion...
Assuming you are not ready for an UP-GRADE
you guys are idiots! it's a Kyocera not a Motorolla! The Kyocera Hydro's bootloader is Locked down, same with it's twin the Rise. So until someone figures out how to unlock the bootloader your stuck. have you tried reseting to facotry defaults? If not here is your instructions and this might help you ^_^
First you remove the battery and reinstall it. With the phone turned off, Press and Hold the Volume Down and the HOME Touch Screen Button (The one theat looks like a little house), and without releasing those two press the power button long enough until you see the Kyocera Hydro logo, when this happens you may release the power button BUT NOT the Home and Volume keys. After a couple of seconds you will see a big android logo on your screen, NOW you can release both buttons. With the volume keys scroll down to WIPE/FACTORY RESET (This will erase everything on your phone except the contents on your MicroSD card). With your power button you select the option of WIPE nad after that it will prompt you with a lot of NO and one YES, scroll with the volume button then choose with the power button. After this you will return to the previous menu, so you just choose the REEBOT NOW with the power button, and voila MASTER RESET.
