Read Ownwer's manual
Lexmark Lexmark X8350 Owner Manual
SOURCE: I have a Lexmark X8350
This can differ b/n manufacturer and models, but basically what you have to do is get in to the printer properties window. Go to File>Print. In the box that pops up, make sure your printer is selected and click the "properties" window. THere is usually a tab that says "Printing Preferences", but like I said, this can vary. Just go thru all tabs and if you are looking to print in black, look for an entry that says "Print in grey scale" or "Economy Print". That should resolve your issue. Be sure to click OK in the box when you're done :O)
SOURCE: Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
