Panasonic Viera TH-50PZ80U Plasma TV Logo
A
Anonymous Posted on Jul 15, 2014
The color has gone out of my picture polarized look
50 inch 2008, can this be repaired paid $2400 for this television and would like to see if fixable
1 Related Answer
Anonymous
  • 14553 Answers
  • Posted on Jun 01, 2012
SOURCE: Panasonic plasma t.v. Has a picture and no sound
Make sure the speakers did not get switched to off.
Or from internal to external if it has that feature.
Also see if sound when a DVD etc. is connected to rear av inputs.
If using a box, a receiver etc--unplug them all and wait a short while and plug back allowing all to try to reboot.
If none of this helps you may have a audio problem in the set--most of these sets the entire audio circuit is on the main board but a look inside at where the speakers connect to will answer that.
2answers
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
3helpful
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
TV Picture
the prism has gone bad, you need a new light engine.
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
1helpful
Thin horizontal line,about 6 inches from bottom,is it fixable?
I am assuming it goes all the way across and is black ?
It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech.
Hope this helps
Scott
2helpful
2answers
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
2helpful
3answers
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
