Question about 3Com Computers & Internet
Boot loader / tiny kernel version 0.70.1v2
3com
3 Suggested Answers
SOURCE:
martyshaw152
  • 157 Answers
SOURCE: Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Posted on Jul 10, 2010
puertobori
  • 7733 Answers
SOURCE: cant download Boot Loader / Tiny Kernel Version: V0.02
Routers don't use kernel.Are you mean recover a Linux OS recover?
Posted on Apr 18, 2013
Neo laptops
NTLDR is the NT loader that loads the kernel.You may have a corrupt boot record. Re install windows is the simplest solution. You may be able to do a windows repair if you have the original OS install disk.
Oct 23, 2013 | Hitachi Computers & Internet
Cant download Boot Loader / Tiny Kernel Version: V0.02
Apr 17, 2013 | Belkin Wireless Surf Router (F7D2301)
Did you mean to recover a Linux OS.Routers don,t use kernerls.
Apr 15, 2013 | Belkin Wireless Surf Router (F7D2301)
Firmware
Hello jagancs1,
[Update]
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
What folder is reboot in
  • Power is turned on.
  • Open Firmware code is executed.
  • Hardware information is collected and hardware is initialized.
  • Something (usually the OS, but also things like the Apple Hardware Test, etc.) is selected to boot. The user may be prompted to select what to boot.
  • Control passes to /System/Library/CoreServices/BootX, the boot loader. BootX loads the kernel and also draws the OS badges, if any.
  • BootX tries to load a previously cached list of device drivers (created/updated by /usr/sbin/kextcache). Such a cache is of the type mkext and contains the info dictionaries and binary files for multiple kernel extensions. Note that if the mkext cache is corrupt or missing, BootX would look in /System/Library/Extensions for extensions that are needed in the current scenario (as determined by the value of the OSBundleRequired property in the Info.plist file of the extension's bundle.
  • The init routine of the kernel is executed. The root device of the booting system is determined. At this point, Open Firmware is not accessible any more.
  • Various Mach/BSD data structures are initialized by the kernel.
  • The I/O Kit is initialized.
  • The kernel starts /sbin/mach_init, the Mach service naming (bootstrap) daemon. mach_init maintains mappings between service names and the Mach ports that provide access to those services.
Mar 08, 2010 | Apple MacBook Mac Notebook
Can we install fedora 11 on Intel d102gcc2 mother board ; I tried couple of time earlier to install various fedora versions , but all went in vain, I think the problem is with sata drivers , please advice!
If you've used live CD Boots, you could try and add nomodeset to the kernel line in the grub boot menu. This would disable kernel mode setting, which causes problems on some graphics cards.
In the BOOT Menu, Press TAB while highlighting "BOOT" Option
Just add "nomodeset" to the end of the text..This disables Kernel Mode Setting and F11 will be up and running....
Oct 21, 2009 | fedora Linux Operating System
Ubuntu Repair Grub
Do you have any other OS's installed? Its with the Grub. mostly looking for another OS. let me know.
Aug 06, 2008 | Canonical Ltd. Ubuntu
Boot loader issue
you have entered the boot loader program by pressing*# and end call button i belive to continue just press the red button again
May 23, 2008 | Motorola Mobility RAZR V3
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
