If you have the manual for your machine, check the cleaning/maintenance section to see how to clean around the bobbin. Your machine probably has some method to allow you to release the housing for cleaning, and reengage the housing for sewing. Make sure it is reengaged.
Hope this helps.
hi there
you can go to www.juki .com
under industerial sewing machine youy can download DDL 8700 instruction manual it's same DDL8300 model.
now you can do next steps
1- change needle with new one.
2- you can find tow mark on needle bar the upper mark for adjusting the hight of needle bar bring the needle bar at lower position and check if the upper mark aqual with the lower bushing or no.
3- when the lower mark aqual with the lower bushing at this time the blad point of hook must be at the center of groove for the needle if no lose tow screw for the hook and readjust the timming between the blad point for the hook and grove for needle bar
best regards
ashraf abozid [email protected]
we have moved to India need a 110 to 220 converter, but need to know the amps and watts to get the right one. I have a Viking sewing maching model 540. Can you help?
