SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
SOURCE: Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
SOURCE: Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
