Worked fine til parked overnite 2 days ago turn power on now,,,won;t move and lights flash why
SOURCE: Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
SOURCE: The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
SOURCE: power chair lights
The problem was a bad joystick. A local company came out to replace it and it works fine now.
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
