My Dell All in One Inspiron One 19 will not power on!
Dell Inspiration One 19A Dead - Repair
Face down. Remove the plastic panel covering the sockets at the back. Remove the stand, 4 small black countersunk screws. Turn over and unclip the bottom panel. Unscrew the plastic piece across the computer under that panel. The escutcheon around the screen should now unclip. Unscrew ~8 screws around the edge holding the back to the metal-work. Carefully invert, face down, and lift off the back. The power supply is in the middle. Another bottom piece of metal may need to be unscrewed first. Remove the cover from the power supply. Four screws hold the PC board in the power supply box.
Two green 820 uf, 25 volt capacitors are likely to have bulged tops.
Replace them anyway. Reassemble after testing.
