Question about Garden
How to replace belt on craftsman mower 917377582
    Sergeant:
  • 242 Answers
Posted on Jul 15, 2014
2 Suggested Answers
SOURCE:
  • 376 Answers
SOURCE: belt drive replacement
First you have to remove the top cover over the belt. If it's still on, work it off the pully. Then you have to remove the blade, blade adapter and cover underneath. Put the new belt on the pulley underneath and push it out the slot to the pulley on top and put everthing back together. Hope that helps.
Posted on May 16, 2009
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
What do I do to fix a loose mower belt on a craftsman zero-turn mower
Your belt has stretched. If there is an adjuster available, via pulley, use it till there is no more adjustment. Otherwise, remove the belt and replace with a new, proper size belt.
Sep 08, 2015 | Craftsman Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 | Garden
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
173 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
