Black and Decker USA BLACK & DECKER GrassHog 5.5 Amp Straight Shaft String Trimmer with Logo
AJ Higgins Posted on Jul 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Grasshog my Grasshog string whipper snipper not automatically feed string like it suppose to
James
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 120 Answers
  • Posted on Jul 15, 2014
 James
Expert
Level 2:
Night Owl:
Answers
120
Questions
Helped
24455
Points
273
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
How do you rewind the string on the black and deckder grasshog
It's annoying I know, but there should be a little notch in the spool, wind the string evenly round one groove. notch it, then do the same on the other groove but in the opposite direction. Hope this helps.
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
2helpful
Need Replacement Battery for CST2000
243215-00 is the part number for the Grasshog's battery pack, but that part is now obsolete. However, you can get the internal battery (part #243213-00 )itself from Amazon for $35.99:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
HOW DO I SET THE B&D GRASSHOG FOR EDGING? IT
The lower unit will rotate 180 degrees from the handle and then lock, with the metal guide pointing down.
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Top Black and Decker USA Garden Experts
Jay Finke
Jay Finke
john h
Are you a Black and Decker USA Garden Expert? Answer questions, earn points and help others
