SOURCE: COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: malfunction detected error code c 001a on minolta bizhub c350
Im thinking either it was moved improperly and the image units werent kept level, or maybe just sitting to long caused them to settle in. try (gently) removing the IU's and shaking them (keep them level) in order to unclog or redistribute the developer inside. (imagine sand in a horizontal tube. It has to be uniform all the way accoss the tube, and not settled into any one location)
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub C350 gives error code C-OF36 while making
that code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
