Cub Cadet Street Sign- tractor lawn riding mower parts Logo
A
Anonymous Posted on Jul 15, 2014
Alko drive belt fitting? - Cub Cadet Street Sign- tractor lawn riding mower parts
1helpful
How easy is it to replace Alko lawn tractor Briggs and Stratton engine?
They are pretty basic, especially if the replacement engine is complete with carburator and exhaust. There should be 4 bolts that hold the engine to the mower, the electrical connectors for the ignition and starter, the throttle cable, & the belt pulley on the crank shaft. If you take good notes and pictures of the old engine before you remove it, just make sure the new engine goes back on the same.
Alko 700 ride on mower. Why is the cutting blade not rotating quickly enough to cut and is easily stopped when trying to cut the grass?
This means you need to purchase a new belt for the Cutting Deck once replaced everything should work okay. Cheers, Malcolm.
Jun 27, 2015 • Garden
The blade stops turning when mowing on my alko 9-55 How do I get to the clutch? Could it be a belt slipping?
Check to see if the belt is loose. If so check that the automatic adjuster is not jammed up with grass clippings. The belt may be worn out, especially if it has been slipping for a long while. Note the way it is fitted before you remove it!! Take a photo of it.
Sep 27, 2014 • Garden
How do I replace the rubber priming cover on an ALKO 620 lawn mower?
what kind of engine brigg and stratton or tecuseh what horse power
Sep 10, 2014 • Garden
Alko rotavator
Possible solution
Belt wore out and stretched
There should be an adjuster to tighten the belt
Could spray with belt dressing but not a permanent fix. Have to spray every so often.
Feb 09, 2014 • Garden
Alko Stabiliser Assembly
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
1helpful
Alko 700/620/600 mower brake problem with peerless 700 transmission
Hi, your problem is simple and is all to do with the brake you adjusted. Remove the two bolts, one either side of the brake adjuster, remove the brake assembly, remove clean and lubricate the two pins and the holes they slide in. Reassemble the brake assembly and adjust the centre nut so that the brake comes on and off. This should be about a quarter inch of travel on the short brake lever. Regards Phil.
Jul 23, 2012 • Garden
Alko lawn tractor belt change problem
Remove deck for more space. Remove guard or cover. Replace belt.
May 14, 2012 • Garden
1helpful
2answers
I have stripped my ALKO ride-on mower down to replace the drive belt. However, I cannot get the drive belt over the engine pulley, due to a metal obstruction getting in the way. To det round this, I need...
You will need to take off he main pulley. I did this by knocking in a wood wedge between the drive pulley and the deck and clamping on some molegrips so the pulley did not go round when undoing the nut at the bottom other wise the motor turns, Undo the nut anticlockwise as usual. The pulley assembly then drops down so you can remove the drive belt
Aug 21, 2011 • Garden
Hi. I have an Alko T18-102HD ride on lawn mower that is starting to go very slow in reverse and forward. It gets to the point of slowing to a stop when reversing up a slope. I fitted a new drive belt...
I had the same problem with my Alko going slow in forward and reverse. Believe it or not the problem is caused by a build up of grass cuttings around the hydro clutch mechanism. If you follow the mechanism from the foot pedal you will probably find the actuator is being prevented from engaging by a build up of old grass. Clean it out and you should find it restores normal operation. This has happened to me a few times so now I blow out the grass on a regular basis with an air compressor which stops me having any problems. It also stops a hefty bill from the service dealer :-)
Jan 14, 2011 • Garden
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Daniel Blask
Daniel Blask
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
