Precor 9.33 Treadmill Logo
A
Anonymous Posted on Jul 15, 2014
Stuck key I have precor 9.33, always stuck key.
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Nov 03, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514234
Points
111994
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 29, 2012
SOURCE: Precor 954i the stop button is stuck
try to tight the RIbbon CAble inside for keypads, and tight the upper cable vs lower cable.
2) Adjust the REED swtich, test it, clean it, see the diagram, and tight very well the plug-
God bless you
Precor elliptical stuck key, display won't stay on, cycles on and off every 5 seconds, but won't continue
If you have a stuck key error, you need to replace the keypad. It will not work otherwise.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Stuck key on display
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
Corrective Action
Precor Error Code 05
Ramp on my precor 456i won't move
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. http://www.sportsmith.net/ Use your serial number to find the correct item for your version.
Ramp is stuck
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
How do I release a stuck key in the key panel?
Chances are there is a stuck key on the keypad. Normally the only way to correct this issue is by replacing the overlay and keypad. Use your serial number to find the correct item for your version. http://www.sportsmith.net/
1helpful
Display reads key stuck
This link will help you step-by-step how to trouble shoot the stuck key issue. You'll want to start on page 18.
http://www.sportsmith.net/images/product_support%5Cprecor%5CService%20Manuals%5CCommercial%20Treadmill%5CC954i%20%28120%20VAC%29%28serial%20code%20AEXE,%20ADEY%29.pdf
I have a Precor C846i which started to display 'STUCK KEY' after using it the other day. Tried to use it again and the display still has 'STUCK KEY'. Need to find out the issue and how to troubleshoot or...
It sounds like the stop switch cable has come loose from the upper display. There are four screws on the back of the console. Remove them and pop the front display loose. Check the the small green circuit board that is under the directional pad. Make sure it's cable is connected and attached to the main board.
1helpful
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Precor c546 self generating elliptical resistance on all time
this is a common problem. We work on Precor. We can get you a cost for that panel. The membrane is defective visit us a www.nashsfitness.com
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
