I need to find a replacement throttle control shifting system for my boat
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
SOURCE: My husband removed the ignition on his 1998
On the back of many ignition switches there are letters by the terminals. B=battery usually the heaviest wire, S=starter, I= ignition which means the coil and full time powered devices, A=accessories as in things that work both on demand (radio) while engine is off and while engine is running. Hope this helps.
SOURCE: I need a wiring diagram for a 1990 heritage 1600
wiring diagram for a 1990 heritage 1600 starcraft boat type this in and do a web search. Is the wiring for the boat are for the motor? Jim Retired OMC Mech
SOURCE: I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
