Frigidaire FEF336BC Electric Kitchen Range Logo
A
Anonymous Posted on Jul 14, 2014
How much are circuit boards for ovens?
The burners work but the display don't work and I can't turntable on clock displays 12:0
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 17, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288950
Points
2557
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you would like to know the price of the circuit board of your oven. Can you elaborate prior to your problem any other symptoms? For instance, did notice any error codes, or other strange functions? Also, may I have your model number please? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem before you take this step?
5 Related Answers
Anonymous
  • 76 Answers
  • Posted on Jan 07, 2007
SOURCE: Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Anonymous
  • 135 Answers
  • Posted on Aug 09, 2007
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Anonymous
  • Posted on Dec 06, 2007
SOURCE: oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 02, 2008
SOURCE: Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Anonymous
  • 464 Answers
  • Posted on Nov 16, 2009
SOURCE: frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! [email protected]
Jenn air svd46800 not working
I'd be on the hunt for a burned fuse I could replace, on those two circuit panels. If no fuse(s) can be found, I would be sad to think the circuit board itself got fried, and new ones can be goofy expensive, so here's to you finding a burned fuse!!
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
2helpful
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
3helpful
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
31helpful
4answers
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Display intermittant for few weeks, now no display or oven control
real easy trouble shoot, check the wiring diagram out and find where the line voltage goes into the board. if you have voltage to the board and no display it is very likely a bad board also make sure you have ground pathway from the board. you can have voltage to the board but if no ground pathway then the board will not work. a cheapo meter from sears etc. will work
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
1helpful
2answers
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
