Question about Dewalt Folding Retractable Utility Knife Dwht10035l
Dewalt instructions can not get blade to stay locked in
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
None that style stay locked because your fingers depress button accidentally I like a Sheffield original with the two hinged pieces that fold around blade like Lamborghini doors. The button is bad idea
Posted on Jan 26, 2017
SOURCE:
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Can't get the blade to stay and lock.. what could be the problem?
Try spraying WD40 down into the blade holder. The pin which holds the blade may be sticking.
Jul 31, 2011 | Dewalt DW304PK reciprocating saw kit with...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
Where can I obtain a set of operating instructions for a dewalt 739 band saw
I HAVE A WOOD CUTTING BLADE #28-565 AND NEED INSTRUCTIONS ON CORRECT WAY TO INSTALL THIS BLADE?
Aug 02, 2009 | Dewalt Saws
Dewalt Folding Retractable Utility Knife Dwht10035l Logo
247 people viewed this question
Top Dewalt Electrical Supplies Experts
Sheldon Dedek
Craig Butler
Craig Butler
John Trevino
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
