2009 Audi A3 Logo
A
Anonymous Posted on Jul 14, 2014
Replace parking lights on 2009 Audi A3
Front parking light, driver's side, replacement, how?
chris marchese
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 48 Answers
  • Posted on Jul 29, 2014
chris marchese
Contributor
Level 1:
New Friend:
Cheetah:
Answers
48
Questions
Helped
13047
Points
68
Gotta remove headlight. replace the blub next to the hid tiny blub common problem
5 Related Answers
Anonymous
  • Posted on Jul 11, 2009
SOURCE: Audi A4 need to replace rear brake light on audi a4
Inside the boot is a plastic cap embeded in the boot liner. Remove the cap to reveal a screw. Undo the screw and the whole rear light cluster will come away in a sideways and not rearward direction to reveal all of the bulbs. Hope this helps.
Anonymous
  • 1111 Answers
  • Posted on Aug 24, 2009
SOURCE: Audi A3 hazard lights keep flashing when parked. I
is the switch fully depressed ? otherwise most likely faulty switch
Anonymous
  • 1986 Answers
  • Posted on Oct 30, 2009
SOURCE: audi a3 r reg remove inner door panel drivers side
On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
Anonymous
  • 172 Answers
  • Posted on Jan 09, 2010
SOURCE: How do I reset the "service due" light on my 2009 Audi A2 2.0
Press and hold BOTH right and left panel knobs while turning the ignition key to the ON position, the regular ligts come up and cycle. The message 10000 miles till next service should come up meanng the service is reset till next service cycle.
Anonymous
  • Posted on Feb 05, 2010
SOURCE: 2004 Audi A4 headlight replacement
you have to loosen the whole headlight assembly to open the covers behind the lights to actually get to the bulbs. 4 screws, 2 are on the top of the assembly(phillips screws) the other two are hex and attach the bottom of the assembly to the car. somewhat difficult to see but look behind the assembly and down into the compartment and loosen the screws(they don't fully come out) just enough to pull the assembly out. open the black cover behind he low bean and there is the bulb
1helpful
I have an Audi A3 2006 model that only recently when I put the headlight switch to side lights the main beam and side lights come on and stays the same when I put the switch to main beam, with the swi
It could be the switch. But first pull the DRL (day time running lights) relay or fuse from the fuse panel. Check the lights again. If it still does it, replace the switch. If it works right, then you need to have the BCM (body control module) scanned to see what's wrong.
Side mirror blinker
REMOVE THE MIRROR FROM THE BASE UNSCREW THE 2 TORX10 SCREWS AND REMOVE THE COVER DETACH THE BLINKER FROM THE COVER.ASSEMBLE IN OPPOSITE ORDER U REMOVED
How to reset mmi on audi a3 2009
Audi A3 2009 is equipped with RNS-E system. Here's the reset procedure:
How do I reset service computer warning Audi A3 2009
If you have a A3, 2009+ A4, 2005+ A6 or 2004+ A8, or a Q7 and are using the after market software:
Go to guided functions, go to service work, go to reset service light, or something of that nature, and follow the on screen prompts.
Read more: How to Reset an Audi Service Light ' eHow.com http://www.ehow.com/how_5102925_reset-audi-service-light.html#ixzz1O2fZgRqR
Change rear light bulb
Pull the tail light assembly out.
Owner manual has instruction on how to remove tail light for bulb replacement.
1helpful
2009 A3 boot warning light
boot? an indicator light is on means something is not shut such as a door please clarify boot
2helpful
Audi a3 1998 automatic transmission cannot shift into gear
have you checked the brake lights for operation ?
if they don't work than it is your brake light switch located on the pedal support bracket.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
