You can get the users manual here:
http://h10032.www1.hp.com/ctg/Manual/c00295405.pdf
SOURCE: Cleaning
Yes , you can manually clean the printer usually you can use a lint free cloth to do so. I don't recommend taking canned air and blowing it out. As far as the ghosting goes yes you seem to have a fuser problem and best case is to have service done to replace the fuser!! Hope I have helped!!!
SOURCE: HP Color LaserJet 2600n Installation
hi, you can download the software from this link
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=446154&taskId=135&prodTypeId=18972&prodSeriesId=446153&lang=en&cc=us
SOURCE: HP laserjet 2600N print job stuck in the printer
You will get a message when the spooler has stopped. Now you need to clean out the queue.
%SYSTEMROOT%\system32\spool\PRINTERS This will bring up the folder. Delete every file in there. (It's okay this will not harm anything.) Now you need to start the spooler again.
net start spooler
This will start the spooler for you again.
SOURCE: My 2600N HP color laserjet, The colors are not
Go to HP's web site http://www.hp.com, look for the link to drivers and support. Then find the support and drivers for the LaserJet 2600n printer.
Once there, you can download most anything they have for that printer, for free. It only costs if you want them to email it to you on a DVD or CD.
Download all you can, related to the printer system - including manuals. Follow their instructions on how to install the printer, and get it installed properly by following the manuals.
Once you have done that, you can find the portion of the manual which explains how to get that printer to calibrate itself.
Mine will do it on a timed bases. I have it set to calibrate itself every 30 minutes or so, just to ensure that it works fine ... expecially since I have to print guides and manuals for customers, many of whom are government agencies and the like.
So having the printer calibrated on a constant basis is necessary, to ensure that my contract - with my clients - is always exactly right.
Try that, and I'm sure it will help you.
-a.
