Hello Friend, thank you for your question!
From what you have described it sounds like the compressor is cycling on when cooling is necessary and cycles off when the temperature inside your freezer has reached the set temperature. This is normal. If you feel that there may be some other issue occurring, feel free to go to the manufacturer website where you can easily locate a service provider in your area.
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
SOURCE: I have a frigidaire commercial
try replaceing the overload relay and start capcitor on the compressor,or possible the thermastat control.
SOURCE: i have a frigidaire upright refigirator/freezer seperate doors freezer works but frig does not
See previous answer - suspect short of gas.
