SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
