Question about Epson Stylus CX3200 All-In-One InkJet Printer
Why is Red light on - printer error - see your documentation and call service if necessary.
Cannot get reset to work and red light does not go off, cannot get error message off, no paper jam, just no response at all - all I wanted to do was to clean the head and the error came on. Is there a simple fix to getting my Epson Stylus CX3200 to working again?
SOURCE:
Inky
  • 705 Answers
SOURCE: nazir
There is an error with the scanner section.
Posted on Feb 17, 2008
myob247
  • 1342 Answers
SOURCE: Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
Posted on May 11, 2008
  • 110 Answers
SOURCE: scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
Posted on Aug 22, 2008
issy2
  • 462 Answers
SOURCE: Epson Stylus Photo R220 InkJet Problem
this sounds like ur both cartridges are empty...
Posted on Sep 09, 2008
eric1121
  • 265 Answers
SOURCE: My Epson Stylus Photo RX500's red alert light
Try to read my other posts. I've already posted a "trick" regarding the same problem.
Posted on Jan 13, 2010
What is the meaning of the Red & Blue flashing lights on the printer?
Now your printer in Service Mode.
It's time to reset the printer.
Apr 09, 2016 | Ricoh Aficio SP 100 e Laser Printer -...
Get error message "Printer error: see your documentation and call service if necessary."
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message)
2.) press the "Stop (triangle)" and the "Colour copy" button and hold them
3.) press the power button to power off, still hold 2.)
4.) press the power button to power on, still holding 2.)
5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom"
7.) now press and hold the power button until the printer powers off and powers on again.
May 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Red ! mark. LCD panel says: Error...Printer
The waste ink tank is full.Read this instruction.
If this not help there is a manual reset for this printers but I'm not tried yet.
  • Press and hold B/W+COLOR+STOP button.
  • Press power button, don’t release all button until you see the led indicator blinking and a message display on the LCD.
  • Release the button.
  • Press COLOR button to clear protection counter
  • Turn off the printer by pressing power button.
  • DONE!
Oct 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
It reads Printer Error - see your documentation
this means your printer waste pads are full and the printer needs to be reset for it to work again or it can just be reset
Sep 25, 2009 | Epson Stylus Photo RX500 Printer
Trhe printer has stopped working completely
just try to do a hard reset of the printer. this iwll solve the problem.
Jul 27, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error light on
try this site and follow it along
http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&pid=C11C545001
its their support link
Apr 26, 2009 | Epson Stylus CX6400 All-In-One InkJet...
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Scanner error see your docmentation and call service if necessary
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
