SOURCE: Cancel Job
Turn the power switch off. Exit the label program on your computer.
Turn the power switch back on and restart the software.
The reset button wont work because the job is spooled in the computer. Sometime you can cancel it from the computer if you have access to the spooler.
SOURCE: Cancel Job
The only other way you can stop it is to stop the print job from the computer. Press the start button. Press the control panel. Select printers. pick the icon of the printer and double click it. Highlight the print job and press the delete button.
That will canel it.
SOURCE: Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
