Texas Instruments BA-II Plus Calculator Logo
A
Anonymous Posted on Jul 14, 2014
How can I change my TI BAII Plus to calculate business loan payments on a 365 360 basis?
3 Related Answers
Anonymous
  • Posted on Mar 02, 2009
SOURCE: simple loan payment
Reset your calculator.
Input the followinw:
-200,000 PV
5.75 I/Y
30 N
CPT PMT
Note: If the interest is compounded monthly then you have to multiply 30 by 12 and divide 5.57 by 12.
David Shaub
  • 2994 Answers
  • Posted on Aug 08, 2009
SOURCE: what are the keys to calculate mtg. payment when
100000+8%= Divide by 360
Anonymous
  • Posted on Jan 07, 2011
SOURCE: how to calculate weighted standard deviation using
Easy,
2nd>7 (DATA)
X01= put the first figure then ENTER
Down arrow two times
X02= put the second figure then ENTER
Down arrow two times .. and so on
till the list finished
press 2nd>8 (STAT)
down arrow
and find your stastics
ENJOY
How much is intereston 1 varable 2 fixed rate
interest is interest
fixed is calculated yearly on the principle and is paid 365 days time
variable changes and is calculated daily ( 1/365 part of the interest rate ) and added to the remaining principle monthly
so if you have a loan of $1000.00 on fixed interest of 10% , regardless of how much you have repaid in a 12 month period , it is 10% of the principle loaned
with a variable interest the interest rate could be 10% today, 15% in 2 months time or 6% later on
it is variable
to add to that it is calculated on a daily basis (1/365 of 10%) and added to the principle left after receiving a payment on the loan
so for a $1000.00 the interest is added to that principle at the end of the month if there is no loan repayment or is added to the principle balance after a payment
the difference is that a variable interest rate loan will allow you to save money if you pay off well before the period of the loan but will add almost 2 to 3 times the loan if you pay the absolute minimum for the period of the loan
a fixed rate is where you know exactly the total interest to be paid at the end of term
I have two BA real estate calculator with the same problem. Each one is slightly off in the calculation. Example. $100,000 loan 6% rate 30 year term should have a 599.99 payment and when I input this...
$596.57 is what I get with payments occurring at the beginning of the month. Set it to handle payments at the end of the month. My calculator gives $599.55 for this case.
I'm not sure about the BA RE, but on the BA-II Plus you change the Begin/End setting by pressing 2nd [BGN] and 2nd [SET].
I would like step by step instructions on how to solve a simple TVM equation. i.e. I invest a lump sume of $2400 in an investment that returns 6% annually. How much will the investment be worth after ...
GOOD QUESTION, Patweetyp...
I've got you covered.
Seeing how it's been three weeks since you posted this there's a chance you've already gotten your answer, but let me go ahead solve this for those out there who may have had the same problem.
Background: There are FIVE TVM Keys; and as you would assume, you MUST input FOUR of them in order for the BA II Plus to solve for the fifth. Now let's get down to business.
1. Hit CLR TVM. [This is just a cleanup maneuver]
1a. Hit ENTER [yes, BA II Plus always needs to be told to store the value, ALWAYS]
2. Type in -2400
3. Hit PV [Since you are investing money at time 0, your present value is negative 2400]
3a. Hit ENTER
4. Type 6
5. Hit I/Y [Your annually compounded interest rate is 6 percent]
5a. Hit ENTER
6. Type 0
7. Hit PMT [you do not have any recurring deposits*]
7a. Hit ENTER
8. Type 1
9. Hit N [there is one year until expiration/liquidation/termination]
9a. Hit ENTER
10. Hit CPT
11. Hit FV [this is your ANSWER = 2544]
----- From here, all you would need to do is change N in order to get your other answers (5 years, 10 years, etc) ----
*If your calculation does not require a recurring payment then you really just have a basic equation of value which would be solved faster by hand. (IE, 2400*(1.06)^1=FV=2544).
You'll notice that I underlined "annually compounded" as well as "one year". The reason for this is because you ALWAYS need your interest term to match your time interval. For instance, if you had monthly payments of which you wanted the year-end total you would need a monthly effective interest rate, and N would be 12.
Okay, I hope that helped. The BAII Plus is the best calculator for time-value-money calculations I've come across. When things get more advanced, you will start using the amortization table which cannot be found in any other TI Calculator (from what I know). TVM is perfect for annuities, mortgages, loans, bonds, and more.
[email protected] for more questions.
TEXAS INSTRUMENTS = 1-800-TI-CARES...they are friendly.
I lost my owner manual for my TI BAII plus calculator. I forgot how to figure amortization. $2000 at 10% , monthly payments of $200, how many months???
You can download the manual from the manufacturer's web site at
http://education.ti.com/calculators/downloads/US/Guidebooks/Detail?id=6114
3answers
How do I calculate a mortgage payment?
If $100,000.00 loan: enter 100000. in pv, if interest rate is 5%, enter 5 divided by 12 = %i if 30 year mortgage, enter 360 N enter 2nd PMT to get monthly principle and interest. You may have already solved this problem.
2answers
Borrowed 18ooo-repay loan equal monthly payments in the next 5 years.how much are monthly payments if interest is 5.5% compounede monthly-how much will pay in interest over the term of loan-how do i set...
Once you're in the TVM solver:
On the top line (N=) type in 5 * 12 ENTER for five years of month payments.
On the I% lline type in 5.5 / 12 ENTER for the month interest rate.
On the PV line type in 18000 ENTER
Make sure the FV is 0 and END is highlighted on the bottom line.
Move the cursor to the PMT line and press ALPHA [SOLVE] (that's ALPHA ENTER) and see -343.82 for the monthly payment.
A $25000 home equity line of credit based on 7.8% APR annualized
No. To the nearest cent, the monthly interest is $162.50. The monthly payments only pay the interest, without reducing the principal.
Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
3helpful
4answers
Simple loan payment
Are you putting 30x12=360 for N? Since you have monthly payments, you have to compute it a little different. Also, you have to find the effective monthly interest rate. 1.0575^(1/12) = .4669839%.
Another way is to enter 30 for N and 5.57 for I/Y, and change P/Y to 12.
Hope this helps!
3helpful
How to use my calculator
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=2&appId=6114
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
