Sometimes Freezes when locked, cannot be unlocked unless you do a battery pull. this happens 4 ~ 6 times a day. already tried different ROM's. anyone know what this is?
i have a jiayu and although i dont have a speaker problem, i had an earphone problem. i could not hear my callers when they spoke and it was horrible. i always used earphones when making call until i FIXED THE PROBLEM!!!!. IF YOU HAVE THIS PROBLEM, LISTEN CAREFULLY........
1- PLACE YOUR PHONE ON THE TABLE
2- GRAB A PIN OR TOOTHPICK
3- GENTLY REMOVE THE MESH( THE NET THAT COVERS THE EAPHONE HOLE. be gentle and careful but its easy. once you remove the mesh, then you will be able to hear your call very very very clear!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
The phone Freeze problem. Your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone. You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
This is very common. what happens is the power door lock actuator freezes up and doesnt allow the linkage to move, you may have to use pliers to pull on the lever or remove the door panel to get inside the door and dissconnect the linkage from the actuator, then you will be able to unlock or lock with the key or lever its just the power lock wont work unless you replace the actuator, heres a picture of it and it located next to the latch on the door,
Plug your phone into your charger with it powered off. Power your phone on after a few minutes and enter your unlock code (usually the last 4 digits of your phone # unless you changed it), and press ok. If the phone freezes, let it sit for a while before you do anything with it and see if it comes back to life. If it doesn't and you've been hard-shocking it like you say you've been doing-taking the battery out while the phone's powered on-you'll need to take the phone back in to your service provider for either maintenance or a trade-in.
the main pssible cause of this problem is because you have a lack of memory..try deleting unwanted programs,photos or even music..if still that does not solve the problem then it could be a virus so try installing an anti-virus on the phone and run a scan..
check wiring going to door there is a black rubber boot going to door wires have rubbed to a short. roll windows up and down if locks start working thats the door to check If one of your door locks don t work, check wiring
pull the fuse. the red and green one. Then cut the black line attached to the battery. open the hood then remove the red connection to the battery. Let it stay for five days.
