Amazon Kindle Fire HD Logo
A
Anonymous Posted on Jul 14, 2014
My Kindle 7 will not charge - Amazon Kindle Fire HD
Micha Szulc
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 82 Answers
  • Posted on Jul 14, 2014
Micha Szulc
Expert
Level 2:
New Friend:
Greenhorn:
Answers
82
Questions
0
Helped
14155
Points
120
First thing to do is try to reset your device, you do this by holding power button for over 20 seconds. Also try to connect directly to mains and not charge by usb on the computer.
1 Related Answer
Anonymous
  • Posted on Feb 25, 2011
SOURCE: I have a kindle and connect to usb on a Windows 7
I guess you're trying to eject the Kindle from the task bar "(safely remove hardware". Try going into Start/Computer/right click on Kindle/ select eject. This worked for me when I had the same problem.
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
2answers
My Kindle won't turn on.
sounds like you did everything right
could call amazon see if they can help
or do a factory reset to eliminate software problems you will lose all your data
then there is hardware problems dead battery that won't recharge bad cable connection inside kindle
Reset Kindle Fire When it Won Turn on or Charge
My kindle 7HD worked for a couple of weeks, but now it won't charge or turn on. what do I do?
You probably broke the USB connector that is used to charge your kindle.
You could take it to a repair shop and see if it can be replaced.
How do I boot up my Kindle tablet?
Charge Unit for 2 hours then hold start button down for up to two minutes and then release start button. Keep Kindle plugged into charger while doing this. Rich
2helpful
2answers
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
1helpful
4answers
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
1helpful
I have a kindle and connect to usb on a Windows 7 pc. In the past when I wanted to charge the kindle connected to a Windows XP computer I just clicked on the safely remove hardware icon on my task bar and...
3answers
Brought a used kindle dx and didn't get a manual don't know how to use or what buttons to push
See here: Amazon Kindle DX Support
Once you have the machine running to read anything, the Kindle user manual is a pre-installed eBook on the device and also available for free via the Kindle storefront in case the previous owner deleted it.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
