Cameras Logo
A
Anonymous Posted on Jul 14, 2014
Canon sx50 where do i find the manual to print?
Harrie
Level 3:
Top Expert:
  • Canon Master 6,746 Answers
  • Posted on Jul 14, 2014
 Harrie
Canon Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285880
Points
83153
1 Related Answer
lv_me_2nite
Sharon Hull
  • 4 Answers
  • Posted on Jul 07, 2013
SOURCE: canon SX50 manual
http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sx50_hs#BrochuresAndManuals
How does canon sx50 hs power the clock
From the main batteries. If there truly is no separate battery then a capacitor holds enough power so the clock keeps running while you change the main batteries.
There doesn't seem to be a separate clock battery, how does canon sx50 hs power the clock?
From the main batteries. If there truly is no separate battery then a capacitor holds enough power so the clock keeps running while you change the main batts.
Canon sx50 hs Power button not working
Obviously the battery is not powering the camera. That could mean many things. There is a break-down in circuitry in the camera and you need to turn it in for a professional check-up.
Disable time and date stamp Canon SX50 camera
Press the menu button, choose Date stamp on the "camera icon" tab, and then choose the desired option.
3helpful
3answers
Stuck lens on sx50
A stcuk lens on a Canon Powershot, have it serviced so it's looked after properly. For the Canons, your best bet is: www.CamerasAndParts.com All they service are the Canons and they are not expensive at all. Most service repairs through them are $79 - $89, including service for the camera and parts and labor for the repair, plus they cover the shipping back if you're in the united states. They are the new we recommend for the Canons, good luck with it.
Cant find the right remote switch
I can't find a connection connector for a wired remote, and I can't find an infra red sensor, for a IR remote. Then in the menu settings nothing is mentioned about remote control settings, so I think your camera does not support any remote control. So if you want to shoot on a tripod, without touching the camera, you have to use the Self timer. See the manual page 58
1helpful
Canon sx50 manualDoes the battery charge in the camera?
The battery charges outside the camera using the supplied battery charger. See page 15 of the manual: http://gdlp01.c-wss.com/gds/0/0300008700/01/pssx50hs-cug-en.pdf
May 25, 2013 • Cameras
3helpful
Canon XEED SX50 Multimedia Projector.Power is not getting ON
i had the same problem.
maybe your xeed got overheated and the security fuse blew off.
its easy to turn it back on.
open the housing by unscrewing both side panels
open the top panel screws (they are belo both side panels)
carefully remove the top by tilting the front and bending it to the backside.
now open the 2 screws of the metal shield right above the lamp housing.
below you have two brown cables ending in the heat fuse.
push the switch of the fuse until you hear a click noise...
power should be back up again - BUT the fuse blew for a reason so check all fans and the location where you use your projector for proper cooling!
if this doesn't help and you have some problems with your local power supplier change the power fuse which is right on top of the power cable but the metal plate has to be removed first.
its tough because you have to loosen about a dozen screws...
hope this helps
have fun
daniel
Canon XEED SX50 Multimedia Projector - Poor light on screen
the canon xeed sx-50 should beside its noisyness give a brilliant bright picture. if not check if there ist something wrong with the lamp? is it aged? did you buy it used? the lamp counter can be easily reset... the only reason for a faint picture could be the lamp's age or tons of dust inside the matrix :)
best
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
