LG 42PX5D 42 in. Plasma HDTV Logo
m
mark Posted on Jul 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No inputs work
Whenever i select hdmi , tv freezes becomes unresponsive and needs to be switched off from wall. no other inputs work though it doesn't make it freeze. sometimes odd graphics come up on hdmi but only freeview works fine. any ideas , cheers
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Jul 14, 2014
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005579
Points
237762
Sounds like corrupted firmware. A firmware update might be necessary. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
No inputs working
possible mainboard isn't fuctioning right try reseting the tv from the menu to factory setting and trying again
2helpful
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
My hdmi wont work for the element tv
Make sure you select the proper hdmi input from the TV's input menu. If that doesn't work then try a different HDMI cable.
My hdmi wont work on the element tv
Make sure you select the proper hdmi input from the TV's input menu. If that doesn't work then try a different HDMI cable...
2helpful
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
I have issues with my unit. Sync problems
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
1helpful
2answers
2answers
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
